briggs intek pro 206 running problems
There is no mixture screw and the choke plate is operating correctly. Ne carb made no difference.
Which is why I am suspecting something more serious.
Find out if just one cylinder is causing problem by disconnecting one spark plug wire then reverse. May be sticky valve on bad cylinder if just one cylinder
