Briggs and Stratton 725Ex 190cc
thejoe
My lawnmower backfired and quit running. It is only 3 years old. I replaced the magneto coil and the carburetor. I have great spark, (I used a tester). Even if I spray starting fluid in the carb, or behind the plug, nothing!
dropped valve push rod maybe model, type and code from engine would help us narrow down the possible causes for your problem.
thejoe
Thanks for the reply! The model number is 12-M02-0943-F1-13081962 Manufactured in Aug. 2013.
With good spark, and fuel, that just leaves either compression problems, or timing issues like a sheared flywheel key. Also may want to check the intake pipe. There has been cases where they have cracked.
