Can the throttle linkage go in wrong?????? Engine runs wide open and throttle moves smooth but does not slow down engine
Tom
Yes it can go in a wrong hole or your governor spring isn't hooked up..... I don't know which engine you have ...
Please post the Model number of your engine..... If it's a Horizontal shaft then it will start with 13 then 4 more numbers, there might be a letter in there also.....
Let us know Mon Ami .........
