Briggs 5 hp rus at wide open after needle seat change. Throttle movement no change
Tom7461
Can the throttle linkage go in wrong?????? Engine runs wide open and throttle moves smooth but does not slow down engine
Tom
Tom
Yes it can go in a wrong hole or your governor spring isn't hooked up..... I don't know which engine you have ...
Please post the Model number of your engine..... If it's a Horizontal shaft then it will start with 13 then 4 more numbers, there might be a letter in there also.....
Let us know Mon Ami .........
That's what it was....When I got brave and watched the u tube video about changing the needle and seat and then when I did it and it fixed my original problem (only ran at full choke) I was all jazzed. Been in electronics for 30 yrs and father in law did all my engine stuff and he passed away so now I better learn. So today took the carb back off and moved the throttle linkage to the correct hole and all is well. Thanks for your help
Tom
