briggs 11hp problem
Once again I made a mistake, not enough coffee thisn morning when I posted. Armature air gap should be .010 NOT .020. Sorry about that. I'm surprise that EngineMan didn't catch that.
hi I am around Welsh pool Powys there are two service dealers in the area that I know of that I can try the coil you mentioned is the same replacement as the one I found whilst researching on ebay uk the coil can only be ordered from the us which will cost an additional $19 or 」12 bringing the total to over 」30 or around $50 if it is no cheaper in a service dealer should I look into a second hand item? or are these dodgy thank for all the replies
I have just gone over the page nd seen the last two posts missed them sorry the gap is 0.020 as I checked this with briggs and stratton:rolleyes::smile:
Thought we were talking about breaker point gap.....! which is .020" (0.5mm)
Armature air gap is .010" - .014" (0.25 - 0.36mm)
Powys is a little too far just for me to pop up, I am down near Swansea.
Remember its not just the coil, you will also need a flywheel. Keep looking on E-bay for a coil.
thanks for the reply I didn't know you needed a new fly wheel will it not work with the original?
Is yours not fitted to the inside of the flywheel..?
http://www.ebay.co.uk/itm/Briggs-an...wnmower_Parts_Accessories&hash=item2eb0fc41f3
Can you post up all the engine numbers, and any numbers that are on the coil.
Looking in E-bay U.K only....I see that you can still get item 398811 which is the part number for that engine, take a look....!
http://www.ebay.co.uk/sch/i.html?_o..._nkw=briggs+and+stratton+398811+coil&_sacat=0
Im not sure what you mean by is it not fitted insidecthe fly wheel the wire from the coil does go under the flywheel to the condenser and points but I want to take out wll the orignal parts and replace them with electronic ignition by looking at a vidio on youtube this can be done just by swaping the coil for one with electronic ignition is tgis right?
