skooter94
- May 14, 2014
- Threads
- 2
- 35
So here it what I have found. Running wide open the battery is 12.6. The regulator is  left lead ( stator) -20.6, center ( stator) -.25, Right lead -.25. Unhooked the power wire back to battery and the battery didn't change. With the blades on it still close to the same. So here's anther kicker to it, I was mowing this week and it died as it always does after a few hours, I swapped out the battery and continued mowing. When I was done mowing check the readings with that battery and the same readings, but the battery I took out when it quit still red 12.4 volts. So is it killing the amps and there is not enough to run. I've to the shop numerous times and it's the same thing, keep checking this and that. They told me if the battery didn't drop when I unhooked the power from the regulator it is something one the motor, but now with that battery still showing 12.4 I'm not sure what to do.
