PTmowerMech
Check your valve adjustments. sounds like they are tight zero clearance and probably hard to start both hot and cold due to mavrick air being sucked in making it super lean. as the engine warms up cleances tend to open a bit and valves wil seat. belive clearances should be .004" on all four valves do cylinder one first spin it by hand check agian then do cylinder 2. Theres also a part number change on the main jet and a slightly larger main jet in turn making it richer check your parts diagram
I checked them. They're fine. .06.
