Yes use a gasketThanks slomo on it!
Also The B&S 690971 gasket had note stating that if engine was not originally equipped with gaskets, to use silicone gasket sealant. Is this religion? as why would pros take all the labor time of cleaning up both the valve cover & head .vs using gaskets? Also if you are checking valves every few years, gaskets make more sense.
Same with the intake gasket, original was a red orange type, but I got the B&S gasket with the tradition 2 hole. Big deal or not?
It is a cost cutting proceedure for original manufacture
Also can be used to check if a dealer has actually checked the valve lash
Petrol soaked scotchbrite will remove silicon sealant fairly quickly but you must block off the pushrod tube to prevent globs of it ending up in the sump
