Smithsonite
21st century engineering for ya. You should see what we're dealing with in the automotive world. The newer the vehicle, the more infuriating the engineering. Sad part is, some of it is as simple as maybe installing a bolt so that it can be removed without removing the transmission while it's on the assembly line.
I call this " A$$hole engineering". Been seeing a lot of this in the OPE world too the past 10 years or so. SAD!!
