6 months on my new motor and its broken!
I agree with Engine man........... Take everything off of the shaft of the engine and start it up... See if you have a vibration......
Then turn your shaft by hand and check to see if it's not bent....... All you might need is a sump cover..... Easy to change.....
I can look the part up for you if all is fine with the engine.........
Let us know Mon Ami ~!~!
So is the sump cover the same on all the 20hp briggs ohv?
Did you get down to the bare naked shaft ????? Yes the 20 hp sumps are all the same, except for the ones with a filter
Oil that is Black Gold, Texas Tea........ LOL..........
What bottom piece ?? The shaft has to be naked and free of rust before you can get the sump cover off.........
If you have a piece of the clutch on the shaft then that needs to come off....... Then see if it vibrates........
Did that, fired it back up w/o the pullys and pto... still vibrated. If I pull the sump cover off, will I be able to see the counter balance assy?
