Black Bart
yes. then I removed both plugs set em on the block connected the wires.spun the motor with starter.yep there both sparking.
then installed em,started it up dripped some gas into the #1 side of the carb and it ran like that cylinder was working.but only while I dripped gas into the intake of #1 cyl.
it has a 2 barrel carb.
Sounds like a carb problem then.
