1995 MTD: Lubricate blade / deck spindle?
I am not bragging, or anything, as it is quite sad that this is even an argument but I hate seeing someone giving out bad advice....... I hate being on a site that has a bunch of kids giving advice about things that they know nothing about, and attack anyone that does.
I even wiped it off so you could see it.
If I say I have something or did something then I do.
I only give advice when I have done it and it works.
I also ask for advice.
When it comes to engine repair I don't post on here I send a PM to who I think knows the most about engine repair
Now that is some silly chit!!! You had a moron tap a zerk into the pulley above the spindle, which just has the shaft behind it, and the "sealed"
bearings below it, and call that a good response??????
Thankfully there are not that many morons here!!!!!!
Admit it, you have been doing some serious Googling!!! And that is the best you could find!!!!!!!
You took it off the mower for us and wiped it off, how thoughtfulll.
***** I do not have time to look for fake pics. Unlike you I have a JOB
The bearings are not sealed and the grease goes to both bearings just fine.
Only you would grease a sealed bearing.
You can buy the sleeve with the zerk on it.
I get that all you know how to do is look up parts.
You like to get **** going.
According to you you are the only one on this forum that knows what they are talking about.
You ask for model numbers then don't know how to help them fix it so you go on your rampage of 20 comments saying dumb **** just talking to your self.
I am done trying to match wits with you as you are out of ammunition.
Before you ask for a model number it is.
F15U3C1k. Y67O5U
Out of ammunition? You show a redneck jacked up deck, with someone stupid enough to tap a zerk on the top pulley shaft above the bearings,
with nothing behind it but the splined shaft.
the deck looks like it has been hanging around a bit.....
It is still real hard to believe that you are serious....
So how are you suggesting the grease gets down there to the bearings???
