Yes, at the main office which is only 100miles from my place.
I got George home last night so I didn't get a chance to test the changes made.
It toke me two days to make and install, I sure it would help if I was a machinist.
In the "It looked good on paper" category. I had planed to have the chain/gears tucked up
inside the tire rim to help keep crap out of it, but with the gear sizes used, when the chain
is tight there was only 1/8 of an inch clearance between the chain and rim, and with the run-out
in the rim(cheap rim) I could see it hitting at some point.
Tommy
All opinions expressed are mine alone, and subject to change as information is gained.
