Originally Posted by demhustler
Raven says - to go 17mph transport speed, deck should be removed and gear manually switched from underneath the mower - if it's true, such transport speed pretty much useles...
is there safety switches engaged in regard to speed and ways to bypass it?
2. specs say: 46'' deck, 2x23'' blades. how much blade overlap?
That's true, but it's very easy to do - lower the deck, remove three cotter pins, disconnect electrical plug from rider, pull out deck, and finally move small transmission arm underneath to ATV mode. This is all done in under a minute or so, the other position for the transmission arm is for the slower mowing speed.
As far as the overlap of the blades; if I recall it was just a tad. However, the mower did a great job; it was just the rest of the machine! :thumbdown:
Although, now that I have the Husqvarna YTH24K48 I'm now a happy man! :thumbsup:
