silver1
I had the same problem with my wheels. I did brake the axle clip and the axle came out with the wheel on it.
Then I put it in a bearing press and pushed it out.. I then learned the inside of the trans-axle. I have another
set that I need to get off and they have been soaking for three weeks and don't move yet. I may try to move
the key back and forth. Or maybe I'll remove the axles and press them off!
It looks like you have one ring clip and one "E" clip. Remove both. Try a puller using the holes, but be careful
not to bend the wheels. Are you going to restore or just use the mower? You may just want to get new wheels
and cut off the old ones.....
LB
LB
