lawn mower fanatic
- Jun 8, 2012
- 6,749
Yes you can angle it anyway you like. Mounting on your mower bar would be no different than mounting it on a bicycle handle bar. Just adjust the mounting bracket. During the day you can just slide it off the mounting bracket and leave the light at home. It can be mounted over the bar or under or on the side of the bar. Keep in mind if you buy the EL530 your mounting bracket will be a little different but they both will do the same thing and it will come with rubber inserts for bar sizing to make it non-slip.
View attachment 9622View attachment 9623
That is pretty nice! I think I am going to get that!!! It is a pretty good price for a bright light like that....there are some lights I have that aren't nearly as bright as you say this one is that cost even more!
