krismanten
On a FL25C, the cutting head is starting to freeze up and not turn. It is a detachable 2 piece shaft. It heated up and melted the head earlier. We changed the lower shaft with the head on it about 6 weeks ago and it worked fine and it all of a sudden stopped turning. If you detatch the lower shaft, the cable will turn fine until you screw the lower shaft back on. What could be wrong?
