How can you take off the blades on a ztr?
bjc
Does anyone know how to change the blades on a Timecutter, w/o a lift, or is a lift the best way to go?:cool:
Parkmower
Or drop the deck
bjc
Ric, i have seen those, but they are expensive and my mower is 50'', this is 47:thumbdown:
D2hornets58
Sometimes I put loading ramps on the tailgate of a truck or on a brick wall. Then i drive up them until the mower is steep enough to get under. Then i put on the brake and put a block or something behind the back tire to stop it from rolling. As long as your careful you shouldn't have any problems.
txzrider
I used to do the ramp thing or sometimes just use my floor jack. I bought a mower so I did not have to... http://www.countryclipper.com/files/files/standup_deck.wmv
I do really like the mojack lift. The only problem I see with it... is all the times I had to check under the deck when I was away from the house.
Ric
You better check again, it doesn't matter what size the cut, it's the distance between or of the front wheels and width of your mower is 54.6 with the Deflector Up and that will be wider than the front wheels. Your front Wheel outside span measurement should be around 42". The EZ fits my 48" cut with room to spare.
BWH
Is there any kind of safety stands or something for those jacks? It would appear to be somewhat unsafe to get under a deck and rock it around loosing up the blades? Just Asking!
bjc
The mo-jacks are so expensive though, Northern makes one for 160:cool:
