OK... Let's See Your Mower!
Two-Stroke
Here are our walkbehinds:
on the right a SABO with Suzuki 2stroke engine. In the middle a Toro with 2stroke engine and on the left the Klippo Mulcher.
That's an interesting fleet, Mac.
Anything with a two-stroke engine interests me -- as you might guess.
Question regarding the mulcher on the left: what does the pivot point in the handle do? I've never seen anything like that.
Mac 624
The lever is for shifting gear. Klippo has Slow-Neutral-Fast. Front drive. Neutral means, that the mower also can be used without selfdrive.
Two-Stroke
Actually, my question was about the whole X-shaped handle, which I now believe is designed to come apart for easier storage. I've just never seen a mower with a handle in that shape.
Here's my two-stroke mower, an incredible Lawn Boy model 7266.
This is a photo of my faithful Jacobsen. It's only a B&S four-stroke so it's obviously inferior but I keep it 74 miles away from the Lawn Boy so it won't get a complex.
Two-Stroke
This one isn't a lawn mower - it's a rough-cut mower - good for brush clearing. It's a Billy Goat brand and has a Honda model GXV340 engine -- alas, a four-stroke, but at least it has overhead valves. The mower has three forward speeds and reverse.
Muhammad
Administrator
Staff member
I used to have that exact same Lawn Boy... also had the bagger attachment on mine. No photos. :smile:
Mac 624
35 years ago, Lawnboy was offered by Stihl. Same design like on the pic. I do not know, if they ever have sold one.
The Xshape of the handle at the Klippo? You can not see it on the pic very clear, but there is a screw, which can be loosen with one hand, so You can go beside the mower, to reach corners or work under bushes.
KLIPPO -
New Model, but nearly the same the ours.
briggs
here is my 60s vintage jacobsen 2 stroke it runs and cuts pretty good for its size
RobertBrown
UGLIEST MOWER CONTEST 2010
Here's my entry, enter your if you like, however I think the winners clear:rolleyes:
