Berniebac
I was driving my tractor testing the brake adjustment that I had just completed when the main steering drag link broke. The ball popped out of the joint. See attached pictures. Is there a way to repair this or do I have to find a new one? Where would I look for a new one for a 30 year old tractor?
Also, I just installed a new battery and thought I would check the charging system. With the engine idling, or revved to half throttle all I get on my meter is 12.64 Volts. I thought I read where it should be above 13 Volts. Is that correct or will I be OK at 12.64?
Thanks
Thanks
