Westwood 12HP Charging Issue
I agree, but most people on this forum don't have or even know what a DC shunt is or does. They can easily check voltage, which very seldom gives false results and is a great place for them to start.
I understand where you are coming from. Its everyone to there own.
When it comes to decorating im crap! :laughing:
Luckily when its only 2 - 4 amp alt they can use their meter and hopefully not blow it up.
When somebody comes on with a problem with a charge problem and the amps is over 10 thats going to be fun!!
Right thanks yet again for the replies.
I have tested the DC Amps and found out that it fluctuates between 3.5 and 3.8 amps.
I take it this is okay then?
I am rewiring the whole tractor now anyway so if there is a problem with the connection to the solenoid it will be sorted out anyway.
Thats what you are looking for so you know the alt is charging so any issues are with the tractor either wiring or the battery has had it.
I think it is highly likely its the wiring because it is really old and in very poor condition. The battery is almost new so it's unlikely its that.
Thanks for the help! :smile:
