honda self propelled
Does the mower have a throttle lever?
Maybe the throttle lever and/or cable is out of adjustment.
What is the model number and serial number (on the upper back of the mower deck)? I can look up the engine speed specification for you.
-Robert@Honda
Caveat: I work for Honda, but the preceding was my opinion alone.
Got a model name and serial number? I can look up the specs for you.
You'll need a tachometer to measure engine speed, or have a shop check it. The throttle and governor linkage can be adjusted if the engine speed is too low.
