Gproc49
- Nov 28, 2026
- 8
I replaced the line from the crank case. I'll check the parts store for a spark tester. I tried grounding the plug against the motor and frame, but never got it to spark! Brand new from the local parts store. This plug was a champion and this parts store has a repair shop also, I never gotten a bad plug before but... I may try one more. I appreciate the help.The light bulb tester isn't a good indicator. The gap spark tester is much better. You can use a grounded spark plug for a step up from the light bulb. The gap testers let you set the gap and can tell you a lot more. Look out for clone plugs, there's a lot of crappy plugs out there. Buy a plug from a known company, from the auto parts store. I don't think you have a glow plug though.
What got the fuel flowing by the way?
