D105 fuel delivery problem.
Gproc49
Hi all, I'm just another guy looking for some help with my D105. I purchased it in 2013 and have been able fix everything over the years until now. Won't start, I replaced the spark-o-later (it was time) fuel filter (same) and the fuel pump (it was not pumping). I have spark down front and the little plunger in the bottom of the bowl operates freely (with the key) I pressurized the tank to get fuel to the fuel filter but it doesn't appear to be going any further. Im not sure how much suction needs to be produced by the crank case but it doesn't seem very strong. Hopefully the knowledge provided by the members here can help solve my problem, TIA
You pressurized the tank, but the fuel is not passing the filter? If you remove the filter, does the fuel flow? If it does, replace the filter. If not, clean fuel tank, and the fuel pickup in the tank. I would replace the fuel lines if they seem old. They break down on the inside, so you don't see it.
Please provide manufacturer and model # of motor for further more specific help. Welcome to the forum.
Hello G.,
Welcome to forum.
We need the engine label information or the numbers stamped in the engine valve rocker cover.
Your description sounds like the fuel tank may need to be removed and cleaned out. Years of dust and grass clippings eventually make their way into a tank and lay at the bottom, then get sucked up into the fuel pickup and lines. When fuel flow is restricted, the engine will not run.
Product ID # 1GXD165EACD109343
Engine S/N 120531ZD55691
I will start with the fuel lines (original) and then go for the tank. Thanks, I'll update later.
Hello G.,
Welcome to forum.
Hello G.,
Welcome to forum.
Hello G.,
Welcome to forum.
I have fuel in the filter. Not getting sucked to the pump. I will change the suction line, filter line going to the pump and the line to the carburetor. Should I pressurize the tank while cranking? I'll update you later. Thanks
What about replacing the filter? You said you have fuel in the filter, does it flow through the filter? If yes, but no further replace lines and test again.
Take the fuel line going to the carburetor off the fuel pump and crank the engine over. It should get constant spurts of fuel as the engine is cranked. If it does, you have a stuck fuel needle in the carburetor.
If the pump only produces odd spits of fuel and bubbles, you have a blocked fuel tank pickup or fuel line. If this has a 90- degree elbow fitting at the fuel tank, that is a definite problem area for a blockage
Thank you, got the fuel flowing! Now I can't get the new plug to spark.. RC12YC, gap at 30. My test light flashes (when I crank the motor) with the probe on the end of wire (clamp). Put the plug in, snap the wire on (tight) and crank... Nothing, wet plug no start. I will try another new plug tomorrow. Thanks for the help and I will update you later.
The light bulb tester isn't a good indicator. The gap spark tester is much better. You can use a grounded spark plug for a step up from the light bulb. The gap testers let you set the gap and can tell you a lot more. Look out for clone plugs, there's a lot of crappy plugs out there. Buy a plug from a known company, from the auto parts store. I don't think you have a glow plug though.
What got the fuel flowing by the way?
