MZ54 Mower Deck
wv109323
I have a MZ 54 model number 96795370200. The machine has 237 hours on it. I have replaced a total of (3) idler pulleys P/N 532196106. Then the bolt p/n 588438301 broke on the other idler pulley. This bolt is threaded into a piece of 1/8" metal welded to the deck. The bolt is a 7/16 bolt. Is this common? This design looks poor and insufficient. To bet it all that bolt was impossible to remove. I was just wondering if others have experienced this problem and possible solutions?
Rust eats away at all of the deck component and eventually the deck shell. Sounds like you need to drill and extract the broken bolt portion so a new bolt can be installed. Most of the bolts a grade 8 high strength bolts, but they don't last forever.
Rust is not the problem here. The bolt just snapped. Husqvarna stamped / punched/ expanded the 1/8" bracket to make the threads longer than the 1/8" thickness. Broken bolt was impossible to remove. I used every method possible to extract the broken bolt. Kroil with punch, Heat and cool with oil, several times, drill and easy out, easy out and impact. I did everything but weld a nut. Bolt never budged. I do not have a welder.
The original bolt is threaded the full length. The OD if the bolt is about .040 smaller than the bore of the bearing it passes through. The bearing race hammers on the bolt until the bolt is out of round. This hammering must have distorted the threads in the bracket. I had to split the broken bolt and remove in pieces ruining the original threads. I can not go up in bolt size because of the bearing bore. Not a good design.
Bolt was not a grade 8 as it drilled way to easy.
want a shear style bolt where the shoulder length is the height of the bearing and spacer(s).
If the original bolt had threads all the way up, that tells me it was a hardware store replacement and likely a grade 1 or grade 3.
Look like time to use a long enough grade 5 bolt with a lock nut and space the pulley correctly.
Husqvarna replacement parts for p/n 588438301 "screw" shows a full threaded bolt/screw. Bearing flatten some of the threads making it out of round. It would make more sense to have a shouldered hardened bolt in a more substantial threaded hole. the 1/8" plate was a "U' shape (upside down) welded to the top plate of the mower deck. The threads in the 1/8" plate was about 1/4" deep. As earlier the 1/8" plate was punched down to extend the threaded depth to 1/4". Truly a poor design. I hope to use a nut and shouldered bolt and hope to use fine threads. Another thing the original screw was listed as 2 1/8" length. I never heard of a 2 1/8" length.
Geez! Reengineer the thing to suit your purpose and quit complaining about the build quality. We all know equipment these days is not built to last.
I once owned a Chevy Chevette. LOL
BTW the idler that uses the 7/16 screw is PN 532196104 not 532196106 which uses a 3/8 screw.
And yes the screw should had been a partial thread grade 8 screw. Similar problem of crushed threads happens in the MTD steering system.
Since I have the 196104 in the shop so I take a look to see if the spacer hole can be resize for the larger screw after digging the bottom storage box. .
A residential Husqvarna zero turn is by no means, top of the line build quality. They are building these at a price point, like many other brands, and the quality of parts and design is not top notch. If you can make it more durable by slightly altering specific parts, that is fine.
Thinking overnight...
One option is to remove the threads, Drill a thru hole, install grade 8 flange head partial thread screw thru the hole, and finish with a flange lock nut. Select the screw to provide as much none threaded section as possible and shorten the threaded section to provide the clearance at close to the original height as possible.
example
I have work several decks that this was done from the factory.
