MZ54 Mower Deck
wv109323
I have a MZ 54 model number 96795370200. The machine has 237 hours on it. I have replaced a total of (3) idler pulleys P/N 532196106. Then the bolt p/n 588438301 broke on the other idler pulley. This bolt is threaded into a piece of 1/8" metal welded to the deck. The bolt is a 7/16 bolt. Is this common? This design looks poor and insufficient. To bet it all that bolt was impossible to remove. I was just wondering if others have experienced this problem and possible solutions?
Rust eats away at all of the deck component and eventually the deck shell. Sounds like you need to drill and extract the broken bolt portion so a new bolt can be installed. Most of the bolts a grade 8 high strength bolts, but they don't last forever.
Rust is not the problem here. The bolt just snapped. Husqvarna stamped / punched/ expanded the 1/8" bracket to make the threads longer than the 1/8" thickness. Broken bolt was impossible to remove. I used every method possible to extract the broken bolt. Kroil with punch, Heat and cool with oil, several times, drill and easy out, easy out and impact. I did everything but weld a nut. Bolt never budged. I do not have a welder.
The original bolt is threaded the full length. The OD if the bolt is about .040 smaller than the bore of the bearing it passes through. The bearing race hammers on the bolt until the bolt is out of round. This hammering must have distorted the threads in the bracket. I had to split the broken bolt and remove in pieces ruining the original threads. I can not go up in bolt size because of the bearing bore. Not a good design.
Bolt was not a grade 8 as it drilled way to easy.
want a shear style bolt where the shoulder length is the height of the bearing and spacer(s).
