Starter pinion teeth, 14 vs 16?
hdsport
1999 MTD 14.5hp, 42 in deck.
Question...
My top end starter shaft on which the starter pinion rides wore out and would not 'grab' the pinion to rotate the ring gear.
I ordered a kit that has all of the components for the top end.
So, I have a 16 tooth pinion on the starter now. This has been replaced in the past. Not sure if its the correct one, but it works!!!
Not sure if I have the correct number of teeth on the pinion.
The new kit has 16, the one I am replacing us 16.
When I look up the kit for my engine no., is shows a 14 tooth gear.
The gear tolerances are wide open.
Both 14 and 16 seem to work.
SO.....what is he reason for 14 vs 16???
Maybe more torque?
I expect that my new 16T kit will work just fine.
Please advise the reason for the 2 different gear teeth.
Thanks,
Paul.
Kohler, Briggs, Tecumseh, Kawasaki, Honda. Without engine model information we are guessing what you are working on.
Here is the info, thanks for reminding me......
Riding Mower, 14.5hp, i/c quiet 42" deck.
Mower: 13AM690G352 1670874
Engine: Mod 287707- -Type 0224-01
Code: 96072570ZD
I have referenced a 14T pinion when I do a search. A 16T replaced years ago.
My question...with the gear tolerences that seem to be very wide open, why the 14T vs 16T?
I'm thinking maybe more torque ?
Advise , please.
Thanks.
Briggs references the 695708 gear which appears to be a 16 tooth plastic gear for the plastic and aluminum flywheel ring gear. The steel ring gear uses the 14 tooth metal gear. part number 593935
It is a matter of the ring gear tooth design that will allow with number of starter gear teeth to function. Yes, it is about starter torque and the size of the engine. Many engines use the same basic starter. If you took a 16 tooth oof that is what you replace it with.
Engineers and manufacturers often mix and match designs so they can sell more parts. Very little is standardized anymore.
UPDATE:
I received the 'top end' kit for my starter.
It was an original B&S Kit.
Assembled all of the components on the starter.
Installed starter...hit the key and it started right up.
So, before the snow comes, drove it to the garage basement storage, Added some Sta-Bil, ran it 'till the bowl went dry.
I'll pull the battery today and keep it on a trickel charger untill it is needed in the spring.
Thank you members of this forum.
Question...
Maybe more torque?
I expect that my new 16T kit will work or view the clinic on Google Maps just fine.
Thanks,
Paul.
Because there are different ring gear teeth spacing. The plastic and aluminum ones uses a 16 tooth plastic gear. Then there the steel ring gear setup for a 14 tooth steel pinion gear. They are not interchangeable. Briggs even came out with a 15 tooth pinion and ring gear setup. None are interchangeable.
Using the wrong pinion gear will cause problem/ The steel pinion will destroy the plastic and aluminum ring gears. The steel ring gear will destroy the plastic pinion gear. Plus they are binding during the time too due to incorrect gear mesh.
Hello C.,
To keep it simple design engineers are paid to create multiple designs out of different materials so they can sell more "widgets" and create confusion for the people trying to repair their products.
