have the following husqvarna z254f model number 967844901 00. transmission is zc-dubb-3d8c. there is problem with transmissions, they will not move the mower. the drive belt has been replaced. all trash and debris have been removed, by pass linkages work no binding. no signs of any seal problem with the wheels off the ground the transmission performs in reverse and forward and when throttle is increased the wheels increase in their movement. but when tires placed on the ground the mower will not move. any clues
thanks AC
thanks AC
