Bought used not starting. Replaced carb, fuel lines and filter, spark plug. It is getting gas to spark plug. Pulled coil which was set on flywheel @ .10. Ohm tested coil 4k.
Should there be ohms the between the shut off terminal on the coil and the spark plug? If I unplug the wire from coil to switch will this allow the engine to run if its a bad switch or wire or is there another way to test the spring loaded switch with the coil off the flywheel?
