I have a 2006 Cub Cadet RZT50 Model# 17AA5D7P710. The right side goes much faster than the left. I checked the adjustments, made sure there was no air in the system and changed the belt all with no changes. So I thought I would try to resurface the pump and center section. I am not sure if I should keep trying to pry the center section out or go back to trying to get the input shaft out (haven't had any luck getting the bearing out) I have found instructions for units that have a plate that covers what looks like an oil pump that is held on with two bolts, you remove this then knock the input shaft out but this unit does not have that.The transmission I.D. is ZA-AFBB-4D7B-3RJX . Any help would be appreciated.
