Thanks. I suspected the box in the fuse panel was K2.
I went back to check everything again and found the 7.5A fuse blown again. I replaced it and jump started the starter to crank it. The engine runs fine but when I pull either of the handles in, the engine stops. The brake was disengaged so that wasn't the issue. I tried to engage the blade while it was running and the PTO worked fine. Since the engine runs fine, I believe D1 and D2 are OK.
