Trickle charging your mower battery at 2 amps about once a month throughout the year will extend the life probably by about double. Most folks don’t do this and therefore buy a new battery more frequently.I have had good luck with the Menard's batteries. And the 6 month exchange warranty isn't bad either.
Things you take into account is most people don't own chargers, Most people store their mower in a location without electric to plug in a charger, and the majority of people don't even own the wrench to remove the bolts that hold the wires to the battery terminals, so they could remove the battery and charge the battery in a location with electric so they can plug in the charger.Trickle charging your mower battery at 2 amps about once a month throughout the year will extend the life probably by about double. Most folks don’t do this and therefore buy a new battery more frequently.
So true and costly.Things you take into account is most people don't own chargers, Most people store their mower in a location without electric to plug in a charger, and the majority of people don't even own the wrench to remove the bolts that hold the wires to the battery terminals, so they could remove the battery and charge the battery in a location with electric so they can plug in the charger.
