Is there a reliable source where I can buy the exact same flywheel as the original OEM part? Since both flywheels have the same casting number (215700) but appear to have the ignition magnet in a different position, I want to make sure I get the correct replacement.yes. The timing is off with the new flywheel. Not just off but way off.
The simplest solution until you can find one, and there are none on ebay that I could find. New is NLA and no one is posting a superceded number. You can pull the rest of the magnets off, use a rotary sander to remove the epoxy that held them on, and run it without charging. The other alternative until you can find a replacement is to take both to a machine shop, have them measure and weigh the two to be sure they are similar in size and weight, then have a new key way cut in the right location. Neither may be optimal and frankly, all bets are off as to whether a new keyway would eventually cause a crack on the old key way, or the new one. Finding a shop that can cut a key may be hard, and even then getting the timing right may not work.
A mower bone yard may have one. There is one on ebay but it is probably as much $$ as a new one.
not when they are brokenAnyone have success gluing the magnets back on?
| A good used flywheel with good ring gear and tight magnets, use before code date 12071800 removed from a 2002 17HP Briggs & Stratton Engine model 31C707 type-0230 E1 code-020730ZA parts may need cleaned last pic is the engine that part was removed from Buyer responsible for fitment, pictures are part of description |
