JustinRaney
Theres a large o-ring on the top of elbow to the carb that the air filter or top plastic piece fits on with the air cleaner. Where can find a replacement part for murray 425001x8 mower?
its maybe 1.5" on the black 90 degree elbow that goes from the carb to the top plastic engine housing with air filter. It seals keeping dirt debris from entering the intake tract.Its probably this one, but check your engine model to be certain.
Briggs and Stratton 270344S O-Ring Seal - Jacks Small Engines
425001x8 is the model number of the mower,. And had no reference to what the model number of the engine is. We need the model number from the engine itself to look up parts for the engine. Murray didn't make the engine and the mower parts diagram doesn't show parts for the engine.its maybe 1.5" on the black 90 degree elbow that goes from the carb to the top plastic engine housing with air filter. It seals keeping dirt debris from entering the intake tract.
Its just like this except a red engine cover with a side brick size flip clipped rectangle filter.
Murray Riding Lawn Mower | Used Mowers Online
https://youtube.com/shorts/amrO4oScvkg This is a running and cutting mower! Moves well!usedmowersonline.com
Thats the 40" its the 425001x8 42" 17.5hp engine.
This is the engine model.425001x8 is the model number of the mower,. And had no reference to what the model number of the engine is. We need the model number from the engine itself to look up parts for the engine. Murray didn't make the engine and the mower parts diagram doesn't show parts for the engine.
Looks like the Briggs single cylinder Intek style engine so the numbers should be on the valve cover that says OHV.
