I have a Husqvarna LS2042 that I bought used and the front wheels have always been toed out and pretty loose so I finally bought 2 new steering arm and the left steering link. Right link seemed pretty tight though the hole for the link in the steering arm was a bit oval. Put it back together and wheels are still toed out. The right link is the only part not replaced and if it had gotten bent in use, I assume it would have bent more at the existing bends, which would have made the wheels toe in more rather than out. I'm sure the gear selector plate is worn some but I assume that that would just cause play between in and out, not permanent toe out. Any thoughts on what else might be going on would be appreciated. Thanks, LP
