got a bit of a trouble leak on a 445 rancher
it is leaking from where the main supply line seals into the tank. replaced the line and she's still leaking. Don't see an obvious crack in the plastic
whenever i prime it i can see air/gas come out and when it is running it also leaks.... now before i replaced the line it would leak whenever you tilted it over or fully filled the tank. Now after replacement it only leaks when primed or running.
I'm suspecting the tank vent. Although i don't hear any release when i undo the fuel cap, probably because its going out where the line seals.
It's got the molded black line
