- Dec 7, 2022
- 2,252
Has anyone had issues with this black plastic transaxle? I have had to drill the input rod two separate times and secure it when the factory one fails.
Also, this one on Husqvarna riding mower I have now from a customer will only work when you work the forward/reverse pedals back and forth by kicking it with your feet. Basically making it inoperable. Ten year old unit. I know these General transaxles are known for having problems. Linkage is not binding, belts and pulleys are good. Do you think it is an internal problem?
