Riding Mower advise
For a half acre and "reliability over price," here's the framework I'd use:
Skip box-store residential. Anything with "Home Depot exclusive" or sub-$2,500 will give you 5-7 years of frustration. The engine, deck spindles, and transmissions are all built to a price point.
Look in the "premium residential" or "homeowner-grade commercial" tier. Examples:
  • John Deere X350/X380 series — your dad's experience tracks here. The deck quality on the X-series is significantly better than the entry-level E-series. 42" deck handles 1/2 acre in well under an hour.
  • Cub Cadet XT2 with Kawasaki engine — solid alternative, often $400-700 less than equivalent JD. Avoid the Kohler-engine versions.
  • Toro TimeCutter zero-turn (residential class) — if your lawn is mostly open, a ZTR cuts mowing time by ~40% vs. a tractor and is dramatically more fun to operate at any age. Learning curve is small.
For a 76-year-old with comfort in mind specifically:
  • High-back seat with armrests is non-negotiable. Test sit before buying.
  • Hydrostatic transmission (foot pedal, no gear shifting). Standard on most JD/Cub units now.
  • Cruise control if available — saves you holding the pedal.
  • Power steering on JD X-series is genuinely worth the upcharge for your hands.
Avoid 60" deck for half acre — overkill, and harder to maneuver around obstacles. 42-46" is the sweet spot. Buy from a dealer (not big box) so you have local service when something breaks in year 5. Spend the extra $200-300 — you'll save it on the first repair you don't have to figure out yourself.
I tested current options for reliability and ergonomics in this lawn mower comparison — the notes on cut quality and operator comfort might help narro
I am now 76 years old and I no longer want to mow my ~1/2 acre lawn - with my current push mower. What brand/ model riding mower would you recommend. I do want a reliable unit, price less of a concern. Any cutting width will likely suffice
My 80 year old dad mowed his 4+ acre "lawn" for many years with a John Deere 60 (??) inch cut riding mower - clearly a leading mfgr choice
Thanks for any advice!! -dave
It depends largely on your health. I have multiple joint replacements/fusions in both hands, wrists and most fingers due to arthritis. Accordingly, hydraulic power steering is not a luxury for me - it's absolutely necessary! I am 75, and when I bought my JD X-370 42" lawn tractor I was mowing my 1/2-acre home lot, but also a pretty rough, steep 1 acre field I bought adjoining my lot. Back issues have forced me to stop doing the field, but I still mow my lawn. In August I'll be having a spinal fusion and a laminectomy, which will cease all my mowing until next season.
Although the X-370 is really more mower than I (or you) need, I am completely satisfied with it. Again, the power steering is wonderful, as is the turning radius. You don't need a deck larger than 42" for 1/2 acre. Remember you have to get it through the door of wherever you'll store it, and a larger deck is harder to maneuver around and between obstacles.
You say price is less of a concern than performance, you'll pay nearly 6K for a new one (that included armrests and a brush bumper), but I love my X-370. Know however, that there is regular maintenance involved (JD or whatever rider you buy) - and regularly. If you are not up to that (fortunately I am), then you'll pay a goodly amount of $ at a dealership.
I would stay away from big box mowers or used ones generally - but that's only my opinion. Good luck!
If this was my situation I would consider paying a landscape company that takes care of lawn mowing plus more as needed. Owning a lawn mower takes maintenance and operation expense. That could cost more than a landscape contractor.
5 pages of - what. Geez. Get thee down to the John Deere dealer and look at the X350. Got
one last summer for the wife. She's just older than you and loves it. Steers easily. Mows great.
Don't be fooled by the JD label on the cubkavarna junk at the box stores. Dealer only units
are the way to go. It's actually the same price as a Husqvarna that splits in two after a few years
and has a much heavier frame with more features. JD has the only steering wheel mower left.
If you wanna give ZT a try: Gravely has a nice small one and I got a BadBoy Rambler that
works.
I can't believe guys would recommend a Snapper RER. They were great for many years and
that ended in the 80's! I got one in 2006 and gave it away after several summers of endless
repairs and parts hunting.
BTW: We know a 95 year old lady who mows with a push mower and weedeats her whole
place. Age is in the mind. Well, and the knees in my case! And the back. Oh well.
Have you considered an auto mower - I am mowing my 1/2 acre as we speak with a Stihl IMow, have had it for 5yrs or so. Depends on you terrain but I am happy with mine and frees up time for other chores. I am 68 and still work a 60 hr week so my off time is precious. Used to spend 2-3 hr/week that are now used for other chores. Don't cost any more than a good rider.
Get a Cub Cadet Ultima ZT1.
I would caution the OP Not to just jump blindly on the "Get a zero turn" bandwagon. (This will upset the "ZT True Believers," but I can't help that.)
And I speak from some experience, having tried to make the Ryobi electric 42" inch zero turn mower work for our two acre property, for a season. It failed miserably, despite my following battery "break-in" procedures religiously. It would only cut for 76 minutes. Admittedly, I let our lawn get high before I cut it and I expect a lot out of my mowers. Also, 76 minutes would be more than enough for the OP's property.
Rather, my concerns are about the OP's SAFETY. The Ryobi ZT pulled an unexpected "wheelie" on me, when I went just went a couple of feet up a slight rise in our property. (And while technically a senior citizen, I still ride dirt bikes, although I do not wheelie them, so I am not completely enfeebled. Not yet, anyway. LOL)
The Ryobi also lacks a ROPS (Rollover protection structure). I feel that Ryobi's failure to offer a ROPS is just a lawsuit waiting to happen.
Also, as was mentioned, ZTs suck on side hills. A lawn or garden tractor is much more capable--and safer--on side hills, than a ZT.
And despite my ability to operate our Kubota B3000 tractor/loader/backhoe, with it's nearly 8 foot backhoe, I think someone new to zero turns might find the "twin sticks" a bit of a challenge, at least at first. I know I did not enjoy having both hands busy the whole time, as I did not have a free hand to hold a cigar while mowing. LOL
I do second the suggestion for a mower with power steering, as we are all getting older. Also, if someone were to have a temporary arm injury, with power steering they would still be able to mow, one handed, which might not be possible with a non power steering equipped mower.
My suggestion would be to do some research on https://www.tractorbynet.com/forums/ and/or https://www.greentractortalk.com/, both of which have forums for riding mowers. (There may be more non-green brands discussed on TBN than on GTT--I'm not sure about that.)
I would consider one of Ryobi's electric riding mowers that is NOT a ZT, like this one, which I believe also comes with a 38" deck, instead of the 30" deck pictured here: https://www.ryobitools.com/products/46396053602 (This is also similar, stylistically, to the venerable Snapper RER folks keep talking about.)
Ryobi also has some conventionally-styled lawn tractors that are electric, that I know nothing about but just saw myself--and IMO, they're just too ugly to consider. But that's just personal taste.
The nice thing about an electric mower is the near lack of maintenance required. Plus the fact that you never have to worry about your gasoline getting old or your mower failing to start. We just have too much property for an electric mower to work for us, although we do have a self propelled, 20" 40 Volt walk behind Ryobi electric mower that has served us very well and taken a lot of abuse.
And while I have never owned a John Deere product, I have read a lot of very satisfied reviews of there lawn and garden tractors on Green Tractor Talk. Their parts support seems to be particularly robust, as owners claim they can still get parts from machines built back in the 1980s.
I do like our 2005 Cub Cadet 1554 SLT, but it's 27hp and 54" deck would be overkill. And the steering components are rather cheaply made, with plastic bushings that wear out and require renewal, resulting in a higher steering effort then one might expect. Also, apparently the Kohler "Courage" V-twins also had a lot of problems compared to the Kohler "Command" V-Twin in our example. But again, that machine would be overkill for the OP's half acre.
As much as I love the internal combustion engine, as time marches on, if you could make an electric mower work for you I think you would be happier in the long run. They just don't work out well for me, as riders.
Your 76 and tired of the push mower. Your getting a lot of advice for a 40yr old guy. Have you tried a self propelled mower. It's good exercise if your up to it. You didn't say much about your health. I'm 82 and have a 1 acre foot print with a house, small garage and 4 car garage. I used a 42'' 12hp Ranch King $900 new in 1990. My next is a 21hp 42'' $1300 TroyBilt in 2005 I'm still using it. I do the usual preventive maintenance. I've replaced steering bushings and tie rods as needed nothing major. Batteries, Belts, etc as needed. I have a very old self propelled 21'' mower for trimming as needed. I like the rider for pulling lawn carts having 2 sizes for clean up after storms and normal landscape maintenance. Most new equipment should give you at least 4 to 7 years on the belts. Lube is no harder than the push mower oil and air cleaner. Good luck on your search.
I'm 77 and still mow my grass. 14 years ago I bought a Hustler Raptor 42" zero turn with the 22hp Kohler engine. It has been trouble free and it is a pleasure to mow with. I'm not sure how much I mow. I have 7 acres of wooded property and probably mow 3/4 of an acre that I consider to be the yard. For the other parts, I have a 25hp Kubota tractor with a shredder. Mowing on either one for me is somehow therapeutic for me. When my wife determines that I seem slightly irritable, she reminds me that I need to go ride the tractor or the zero turn. Maybe I am weird.
This is called tractor therapy, and it's not weird. I do it as much as I can.
Not all ZTRs suck on side hills. The steering wheel ZTRs do MUCH better. I have both, a lap-bar ZTR and one with a steering wheel. The steerable front wheels are a game changer on hills. A ZTR with a steering wheel is better on hills than a tractor style rider, as the engine sits lower, and both rear wheels are driven.
