I am now 76 years old and I no longer want to mow my ~1/2 acre lawn - with my current push mower. What brand/ model riding mower would you recommend. I do want a reliable unit, price less of a concern. Any cutting width will likely suffice
My 80 year old dad mowed his 4+ acre "lawn" for many years with a John Deere 60 (??) inch cut riding mower - clearly a leading mfgr choice
Thanks for any advice!! -dave
Yeah, a bit of an exaggeration, I'd say. My notoriously heavy Kubota 60" diesel ZTR weighs much less than 2,500 lbs.This, IMO, is a bit of an exaggeration. My ZTR is an entry level commercial/prosumer model (CC Pro Z100), and it weighs in right at 1000lbs dry. 2500lbs is more like my utility tractor. The point is valid, though. The OP doesn't need a big heavy ZTR for 1/2 acre.
This IS one of the advantages of RERs. Most, if not all, of them can be stored pointed straight up, sitting on their tail. Takes up not much more floor space than a push mower.
The steel tube backbone models only. Not the new stamped steel chassis.I'll 2nd the recommendation for a Snapper RER.
Not really. IIRC RER decks start at 30”.Even that will be overkill for 1/2 acre.
My neighbor has a lawn about that size, and he uses a Ryobi battery-powered self-propelled mower and loves it. I'm assuming you don't necessarily want a rider. I have a farm, but the part we mow is small. Our orchard needs to be trimmed to look nice. My wife uses a SunJoe battery-powered mower, and I have been amazed at how long it has lasted and is still going! I do not like weeding the grass between the corn in my garden, so she takes the SunJoe down between the rows of corn. I have never had to change oil, and it has never refused to start! I'm 77 and she is 73.I am now 76 years old and I no longer want to mow my ~1/2 acre lawn - with my current push mower. What brand/ model riding mower would you recommend. I do want a reliable unit, price less of a concern. Any cutting width will likely suffice
Assuming the wheel base width is something less than 42" . I'd recommend a deck that had slightly more width than the tires as it makes edging possible without dragging the tire across whatever is being mowed,Whatever you do, only consider a zero-turn rider. A 42" deck will do you nicely.
