- Sep 7, 2024
- 3,337
You need a very small finishing nail and a medium screwdriver handle to use for a soft hammer. Look at the pin carefully and you will see one end has a dimple because it is flared for a tight fit. The other side is flat. Place the small finishing nail (or a tiny pin punch) against the smooth flat end of the pin. Gently tap the pin and it will free up and move out.
Make sure to put the pin back in the same direction. (Mark the dimpled end and aluminum with a permanent marker for reference.)
Do not get too aggressive trying to remove the pin.
Once the pin is out the float and needle will lift right up. Pay attention to how the needle is attached to the float.
Let us know how you progress.
After a light cleaning, reassemble in the reverse order.
