have the following engine b/s 09p602-0143-f1 the engine will not start blade was bent, checked key on flywheel looks to be good, valve clearance is greater than specs. looking to find a procedure to adjust the valves, hopefully after adjusting valves the engine will start
thanks
AC
thanks
AC
