Backfiring through the exhaust
Regardless of how thick your business card is, the .010” air gap still is correct for ignition coil to flywheel.
Right
I was using a business cards which was easier than using my brass .010 feeler gauge, finally mic'ed the business cards I had been using and most was .030 plus, out of specs.
electric start eq still operated ok at .030, but seemed manually crank eq such as chainsaws did not start as easy
After setting the air gap at .008-.010 I manually slowly rotate the flywheel with the gauge still installed to check for any tight spots. Sometimes I go to .012 just to be safe that the magneto core does not get scrubbed if the .010 feeler gets snug.
