Ric
Uncle, You and I both know that to see true value one has to be color blind. :wink:
Robert, Good answer :thumbsup: and so true.
I run John Deere and Exmark, The JD EZ series is a good inexpensive mower and cuts almost as good as the 7 Irons. I wouldnt think you would need true Commercial. I still use a EZ425 as a back up and it still cuts great for $4k
Ric, so the fact that an aftermarket company makes impliments which are COMPATIBLE with Scag, Hustler and Exmark (and others) carries-in your mind-an approval by the above makers for attachment of these products to their machines? Next I presume you will state that attaching any of these products affects the warranty of the zt in no way at all??
AND, I am not side-stepping your question, perhaps I am not explaining it well enough; pro's have taken favor with the zt for really one reason and that reason is the zt has the -potential- to reduce trimming time, also those lawn care companies with wide trailers are able to load a zt sideways giving them much more room to transport machines.
