YTH22v46 SN 011019D008646 Thank you Not zero turn. Thanks ILENGINEWill need more clarification since the 4622 brings up Zero turns not lawn tractor style mowers. And if this is a Z turn than it would have 2 hydro's not one, which would lead to more of a belt issue than a tranny issue.
So we will need the actual model and serial number from the mower tag to determine what you have.
Transaxles don’t go out often. They also don’t just suddenly quit if they are hydrostatic. They slowly start failing. Cost prohibitive for a shop to fix. Typically $1000 and up, plus labor. In other words, buy another mower if it goes out.My 4622 Husqv hydro quit working. The drive belt seems fine. The belt seems to be in all the right places. What are the odds of needing a new hydrostat? Can they typically be fixed? How much is new hydrostat?
