kohler carburetor problem
ACF
have a cub cadet zt1 model 17areacsa10 with kohler kt725-3083, the fuel tank had water in it owner drained and flushed but only runs for less than a second. replaced fuel filter. cleaned carburetor, solenoid tested good have 12 volts going to solenoid, still only runs for less than a second, cleaned carb again no change. looking for any help in resolving this issue
thanks in advance
AC
Take any flammable spray juice. Spray it into the carb throat preferable with choke and throttle plates open.
If it runs for 1-3 seconds then dies, you know you have a fuel delivery issue, good spark and good compression.
ACF
good spark and compression so what is the fix
Auto Doc's
Check the fuel shutoff solenoid at the bottom of the fuel bowl. The pintle is likely stuck or the solenoid has failed. Water is not kind to these solenoids.
ACF
in post reported solenoid good and 12 volts going to it
Auto Doc's
Hi ACF,
Yep, I read that. 12V going to it does not mean it is working physically. I've had many that even "click" but would not open properly.
On my own stuff, I just snip off the pintle end and install a manual shutoff fuel valve. But, like I said, that is just my own stuff.
Tiger Small Engine
Hi ACF,
Either the carburetor anti-afterfire solenoid (most likely), or a start/run relay bad. These carburetor solenoids go bad with consistency on customer equipment.
VegetiveSteam
An engine needs 5 things to make it run. Fuel, Air, Ignition, Compression & Timing both ignition and valve. Which one are you missing? From what you're posting, nothing seems to be missing. So why isn't it running? Does it run with the key in the start position then die when you let go? If you could post a video of what it's doing that could be helpful.
ACF
replaced carb and key switch
Auto Doc's
Were all the fuel lines cleared of the water.
