help on finding 14-21 HP Briggs & Stratton opposed twin cylinder engine repair manual
wildjoe
i need to find a manual or a couple parts numbers for a 14-21 HP Briggs & Stratton opposed twin cylinder engine carburator and fuel pump. any info would be apreciated.
thanks joe
Re: help on finding 14-21 HP Briggs & Stratton opposed twin cylinder engine repair ma
Get the model number, type number, and code numbers from the engines, go to briggs and stratton.com, click on manuals, fill in the numbers/letters in the blanks. Click on parts manuals and download. You can save them in pdf form in documents if you like. Repair manuals are available to purchase on line or at a local power equipment dealer.
Mad Mackie in CT
thanks joe
HEY WILDJOE
I HAVE A SEARS TRACTOR WITH THE 14 HP TWIN OPPOSED BUT BETTER YET I HAVE THE ORIGINAL OWNERS MANUAL THAT CONTAINS ALL THE PART NUMBERS OF ENGINE AND TRACTOR. I WILL COPY THE ENTIRE MANUAL AND SEND IT TO YOU . I WOULD VERY MUCH LIKE A PHOTO OF THE GOVERNOR ASSEMBLY THAT IS LOCATED ON THE FRONT OF THE ENGINE BELOW THE INTAKE MANIFOLD
I HAVE PURCHASED ALL THE MISSING PARTS BUT NEED TO KNOW HOW THIS GIZMO GOES TOGETHER NICE CLOSE UP PICTURES SURE WOULD HELP
FORUM MANAGER HOW DO WE CONNECT ?
I can send you a Service Manual/Overhaul Manual covering the 40 series and 42 series B&S opposed twin engines. Giving horse power doesn't cut it. Address below IF you want Manual put in proper format and remind me engine model number and what you want.
Walt Conner
wconner5 at frontier dot com
Walt Conner
Do you still have access to repair manuals for 40 through 42 series
Thanks
