blaster 2023
- May 20, 2023
- Threads
- 4
- 37
The shim washer was left out by an idiot (just a guess). It is what sets the correct side clearance for the assembly to work. It prevents it from walking back and forth and slipping under load.
What prevents the Hex shaft from spinning in the Bearing instead of the bearing and hex shaft spinning together orThe shim washer was left out by an idiot (just a guess). It is what sets the correct side clearance for the assembly to work. It prevents it from walking back and forth and slipping under load.
