- Dec 7, 2022
- 2,247
Ok so Ive checked that out closely and its just the cog gear that is spinning not the motor shaft.Im aiming to swap it with the good cog gear tomorrow or at least take it off to see what the center of the cog gear looks like .If the end of the motor shaft is stripped -do you know if that is replaceable ?
Im in Australia and all i hear from my local lawn mower workshops is its not worth fixing as its too costly to replace the hydro.The mower is in immaculate condition besides this problem and I'm on a pension due to illness and cant afford to replace it.
Weld it up. I have done this successfully on more than one mower with stripped drive pulley on shaft.
