Snapper engine reviving
navydad2022
I cleaned my Snapper (281223BVE) carburetor and it idles ok but when l engage the blade the engine revives up and down.it seems it is starving for More fuel.Can the fuel filter or diameter of the fuel line matter.also could it be air lock and how to prevent it.21A907 0124 E1
I would suspect that either the main jet is partially clogged and not allowing enough fuel under load. Reduce the throttle slightly and see if it smooths out or not. The other thing that comes to mind is the governor is being too sensitive and can't stabilize. Can be either caused by too sensitive of springs , or static adjustment not done properly or even a faulty governor gear.
Thanks,will try to adjust the governor and how would l adjust springs if possible.l noticed that the carburetor adjustment screw does little to adjust fuel.
Not much you can do with the spring. And the adjustment screw would be for idle jet only. the high speed jet would be non adjustable and can cause issues. I haven't come across a similar issue on that size of engine, but have several times on the smaller horizontal intek engines with carb problems causing surging at full throttle.
Would a bad gasket between carb and engine cause bad suction to starve fuel
Some mowers have a filter in the tank and by adding a second filter depending on filtration can cause a fuel restriction.
