Buy a battery with a minimum of 250 CCA (cold cranking amps).
New chargers will not recognize and begin charging batteries that are below 12 volts. Unless you have a charger like a Noco that will charge from one volt up. Use a multimeter and see how many volts you have. 12.75 is a fully charged battery. Obviously this doesn’t put a load on battery.
Use a 2 amp trickle charger once a month to charge battery, whether using equipment or not. Should get 4-5 years out of battery if maintained correctly.
Batteries today, lead acid, AGM, or lithium are very good and priced fairly for what they do. If you don’t keep them charged and kill them a few times, it will severely shorten or end their life.
